Our company standards includes bundle numbers with wirenumbers. These bundle numbers must be seen in the from-to reports.To get this done I use the user attributes (W0xUser) in the wirenumber symbols (WD_WNx). This is working great.
The next first thing I would like is that the bundle number is not seen only at the source but also seen at the destination like the wirenumber. The second thing I would like to know if there is a method to change an W0xUSER attribute visibility state projectwide. Does anyone have an idea how I can get these things to work? I added a printscreen to clarify.
Thanks.
There are separate symbols you need to edit for the wire number copies, did you add that user attribute to those as well?
changing visibility states project wide for attributes is one thing i have been working on
2 methods
1) modify the attrbutte in question in each block and put it on a seperate layer write a script to turn the layer in question on or off goto to project >project wide utilities and run the script
2) im working on is to have a script that seaches the page and looks for specfic attbutes and switches them off or on this is my preffered solution but its a wotk in progress at the moment
Yes, I edited those to but the inheritance over the signals arrows is only working for the wirenumbers. Do you have another suggestion?
p.s. Ive been gone for a while in the project but now im back in the schematics. Sorry for the late response
Im verry interested in this project wide utility to hide or unhide attributes.
I do the following commands every page:
AESHOWATTRIB
ALL
-> ENTER
-> ENTER
-> SELECT W0xUSER in popup
-> OK
is it possible to put this in a script, including the popup handling to get it done project wide?
what i did was go into our symbol set and change the manf /cat number to a different layer i called it OEM and changed the colour
if you go to project settings in the project manager for your project
drawing format>define>
there is a tick box apply to entities on layer 0 as i understand this it then only moves items on layer 0 to the defined layers in the menu if ticked
swapped out all the symbols in the project for the new symbols
then i created a simple script
_CLAYER
0
_LAYER
ON
OEM
_.ZOOM _E
_.QSAVE
which set the current layer to 0 turned on the OEM layer and zoomed extents
now if i want the layer switched off i use
_CLAYER
0
_LAYER
OFF
OEM
these are run from
main menu>project>Utilities
works a treat
what we are doing is creating our own symbol set based on the iec60617 and creating our own icon menu to contol it all
this way we can have information displayed on the set of drawings going to the panel shop and a different set of details to the customer just by running a script
Looking at your example, I think you are running into a limitation of the code. The code supporting signaling most likely doesn't look at those user attributes when copying information from the source side. This might be a good suggestion for the IdeaStation.
