Hi there,
I´m experiencing that after removal of all wirenumbers in my project, I still have some wirenumber leaders and in some cases wirebreaks where previous wirenumbers were placed. I had to manually fix the wirebreaks and erase the wirenumber leaders which is quite time consuming.
I tried using the dwg audit and the electrical audit tools but without any helpful results.
I must admit although having used ACED for several years I don´t have much experience using the wirenumber tool. Maybe I´m not following the correct procedure when erasing wirenumbers project wide and then after some modifications reinserting wirenumbers project wide.
I have attached an image showing what I´m experiencing...maybe someone can give me an input for a quick fix??
Thank´s again, Gary
I have NO idea 😄
Seems a little "crowded" where the wire numbers was located, but nothing that should be a problem.
But, can you recreate this so that you could post a drawing with this problem?
