Are all the neutral wires the same number, in this case "N". To get 4
different neutrals to show up you may need to have different suffix's on the
neutrals (N1, N2...) or have each valve with a different location.
Regards Brad
wrote in message news:5797646@discussion.autodesk.com...
Here is my scenario -
I have a hydraulic power unit which has 4 double solenoid valves.
I show an output from a PLC in the main enclosure going to each valve coil,
I show a neutral wire from each valve coil coming back to the main
enclosure. Each valve location is shown to be the hyd_pu
My issue is when I run the wire to/from report using the main enclosure in
the 'from' and the hyd_pu in the 'to' I get the wire number for each valve
coil, but only one "N" for the entire group.
I would like to show at a minimum a "N" wire to each coil show up in the
from / to report. What am I missing?
I have tried to placing a unique terminal point at each coil, but still
only get one "N", however sometimes when I run the report I may get two "N"
which show up in the report.
I am using AE 2007. Would AE2008 correct this?
Thank you,
Todd
