AutoCAD Electrical Forum
Wire to/from Report
7 REPLIES 7
Message 1 of 8
252 Views, 7 Replies
Wire to/from Report
I would like to add the Component Tag info to a Schematic WIre to/from report.  Can this be done? How?
7 REPLIES 7
Message 2 of 8
testsubject
Not really sure what you are askinng for.
CMP1 and CMP2 are the component tag values.
Could you be more descriptive?
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Message 3 of 8
in reply to: testsubject
Below is what I would like the report to look like.  The tag is the unique identifier of the component.
12/5/2011 10:30:12 AM
 Wire From/To report for Drawing 020.dwg
TAG     LOC1         PIN1     WIRENO    TAG      LOC2           PIN2
WG1    R10-A3     P3-18    WD1-A      IO1        R10-B17     WD2-A
Message 4 of 8
testsubject
John,
I am sorry, but I still do not see what your issue is. It seems like you were able to change the report that was generated to reflect the column titles that you want. CMP1 is the unique component TAG value for the component on the left and CMP2 is the unique component TAG value for the component on the right.
Are you using other fields for TAG values??
Bob Hanrahan
Ace User since 1998
Message 5 of 8
No Bob I cheated.  What your looking at is what I created in word not the what was output from the report.
Message 6 of 8
OK!!  Got it!!!  It's the CMP1 & CMP2 that I need to add to the report to get the tag info I needed. Much thx!!
Message 7 of 8
Also just discovered I can simplify and just request in report format CMP:PIN to get what I need.
Message 8 of 8
testsubject
That is what was throwing me off. The report you showed was what was available from ACE with a little tweaking...
Smiley Happy
Bob Hanrahan
Ace User since 1998
”Boost
