One way to troubleshoot this is to run your wire from/to report for just the
drawing where these phantom WIRES are showing up. In the report dialog
select "Change Report Format" and add in the WIREHDL1 and WIREHDL2 fields
into the report.
Now find your phantom wire entry in the report. You should see a column with
"h=xxxx" entry where "xxxx" is some hexidecimal number. This gives the
AutoCAD object "handle" tag for the wire.
At your command line, type this:
(entget (handent "xxxx")) [Enter] where the xxxx=the entry from the report
without the "h=" prefix.
Example, report column shows "h=5C3D". Type in the above command like this:
(entget (handent "5c3d")) [Enter]
Your command line will now display something looking like this:
Command: (entget (handent "5c3d"))
((-1 . ) (0 . "LINE") (330 . )
(5
. "5C3D") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "WIRES") (6 .
"Continuous") (100 . "AcDbLine") (10 3.93747 50.7643 0.0) (11 3.83747
50.8643
0.0) (210 0.0 0.0 1.0))
The "10" and "11" entries give the end point coordinates of the phantom
wire. You should be able to use these coordinates to locate the line entity
that is causing you some problems.
Nate.
Example
wrote in message news:4893683@discussion.autodesk.com...
When I run the to/from wire list, there are two wires that always come up I
want to get rid of. These wires are in the layer WIRES. I have removed the
wires on the drawing (coincidentally they have the same name) and have
replaced the devices the wires used to run to. I have even deleted the
layer WIRES from being recognized as a valid wire layer. However these
wires are still being reported in the to/from list. Is there a reason why
this could be happening, or a way to purge all memory of former wires and
rebuild the to/from list? I cannot find any reference of these wires or
devices anywhere on the drawing. I even turned off every layer except WIRES
and there was nothing using that layer. Any ideas would be appreciated,
thanks.
