Maybe the Component Wire List is closer to what you want? If not, I can look
further into the possibility of getting this information with a User Post.
Pat Murnen
wrote in message news:5740737@discussion.autodesk.com...
I'm looking for a way to customize the "wire to from" report, and or create
a custom report.
I would like to be able to run a 'wire to from report' and have it retrieve
MFG & CAT attributes out of the schematic component blocks the wire
terminates at. I can retrieve the TAG attribute which has the component
code, but I would then have to cross reference the component code to
Manufacturer. I believe there should be a way to retrieve this information
being that I can retrieve it through other reports. But how can I add it to
the wire to from report.
