AutoCAD Electrical Forum
Wire to from Report - Customization
3 REPLIES 3
cdl5577
169 Views, 3 Replies
I'm looking for a way to customize the "wire to from" report, and or create a custom report.
I would like to be able to run a 'wire to from report' and have it retrieve MFG & CAT attributes out of the schematic component blocks the wire terminates at. I can retrieve the TAG attribute which has the component code, but I would then have to cross reference the component code to Manufacturer. I believe there should be a way to retrieve this information being that I can retrieve it through other reports. But how can I add it to the wire to from report.
3 REPLIES 3
in reply to: cdl5577
Maybe the Component Wire List is closer to what you want? If not, I can look
further into the possibility of getting this information with a User Post.
Pat Murnen
wrote in message news:5740737@discussion.autodesk.com...
a custom report.
cdl5577
That is close to what we want, put not exact. We are really looking for a wire to from report with MFG and CAT info to be displayed. The component wire list isn't quite the same, granted I'm not sure which would be easier to customize to get to the end result.
Maybe if you sent me a copy of what you want I can see which way might be
best. If you want to send it to me directly, send it to
pat.murnen@autodesk.com.
Pat Murnen
wrote in message news:5748234@discussion.autodesk.com...
”Boost
