You can add the command to your ribbon using the CUI editor. I place it between Update/Retag and Utilities on the Project Tools panel of the ribbon. Name it Rebuild DB and set to Large with Text Vertical. Exiting the software and deleting the project scratch database is the ultimate rebuild though. It is good to do this from time to time on a large project that may take some time to complete. Also, rebuild the DB if you have used any plain AutoCAD commands or replaced a drawing in a project using Windows explorer. Think if it this way: If you used a non-AutoCAD Electrical method the database is not updated and must be forced to update.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
