AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wire Sequencing Problem
0 REPLIES 0
Message 1 of 1
treecatt
211 Views, 0 Replies
I am using ACADE 2010 under Windows 7 Professional. I was setting wire sequencing from one terminal that has two separate branches specified by using angled wire entry. The branches cross from one sheet to another. When I set the wire sequence it is assigned to both wire branches even though they are two separate branches going to different devices. I performed a test by creating a new simple project with two source terminals; two branches per terminal each to a unique device. I first tested assigning wire sequence by keeping the wiring on the same sheet. No problem; worked fine. I then moved the device terminals to a second sheet. I tied them across the two sheets using the source/destination symbols. Setting the wire sequence again causes it to be assigned to both branches. I then added a third sheet and transferred two devices to this sheet. Wire sequencing still applied to both branches. I've attached the files.
Any help would be greatly appreciated. One of the primary reasons I talked my company into purchasing ACADE was to be able to generate wire lists so I really need the wire sequencing to work properly.
0 REPLIES 0
”Boost
