AutoCAD Electrical Forum
Wire Sequence Issue
3 REPLIES 3
476 Views, 3 Replies
Wire Sequence Issue
I'm having difficulty getting the wire sequencing to work correctly. I completely deleted the wire and re-drew it connecting only to 4 components, but when I go to do the wire sequencing it is still showing the other components that are no longer on that wire network. Am I missing a step?
3 REPLIES 3
dougmcalexander
Did you delete using AutoCAD erase or AutoCAD Electrical delete?  Try a database rebuild.  Go to the command line and type AEREBUILDDB, press Enter, and click Full Rebuild.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
in reply to: dougmcalexander
Thank you that worked Smiley Embarassed I should have known to try that.
dougmcalexander
Glad that helped.  Kudos are appreciated.
Anytime you catch yourself using an AutoCAD command on an Electrical drawing, rebuild the project scratch database.
Hint: Use the CUI Editor to add the Rebuild/Freshen Database command to your ribbon.  I suggest locating it on the Project Tools as shown in the attached screen capture.  After you move it up to the ribbon panel click in the Name field at the right of the CUI Editor and name it Rebuild DB.  Set the buton style to Large with Text Vertical. (see attached screen capture)
Doug McAlexander
”Boost
