Carl,
Two things.... 1) after you run the SS->PLC I/O generator utilty, you can't
re-run it and have it just make minor changes to existing dwgs... it creates
a new set of dwgs. 2) as far as controlling the wire layer assignment from
the SS->PLC I/O utility spreadsheet, good idea, but it's not currently "in
there". Customers are encouraged to use this utility's source code
(c:\program files\autodesk\acade 2004\support\wdio.lsp and wdio.dcl) and
create a custom version by modifying the program. It probably wouldn't be
too hard to add a new columns to the spreadsheet to comma-delimit an
existing column's data to force the connecting wire to a specific layer.
Nate.
"Carl Smith" wrote in message
news:40d1e560$1_1@newsprd01...
> Is there any way to force wires to specific layers from within a
spreadsheet
> that generates PLC drawings? As far as I can tell all of the wires
> automatically "go" to the first line layer in the configuration.
> cds
