AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wire Numbers
1 REPLY 1
525 Views, 1 Reply
Wire Numbers
I have been trying to do a wire number update and all of the wires are updated except for one. It seems that no matter what I do, I cannot assign a wire number to this wire. I have deleted the wires and re-inserted them many times. Any suggestions?
1 REPLY 1
OP21
Couple of things...
Have you tried running DWG Audit? (Command: AEAUDITDWG)  This may help locate and/or clean up dwg objects and the database.... Try adding your wire number to the wire....
Also check..->Wires/Schematic/  "Edit Wire Number" or (Command: AEEDITWIRENO) to see if the wire may be set as "fixed with a blank or empty field" or if it was set to "hidden"
Thanks!
Omar
Hope this gets you closer to a solution... and if it does... "accept as solution" and kudos are appreciated...
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
”Boost
