AutoCAD Electrical Forum
Wire Numbers?
1 REPLY 1
Warchild214
139 Views, 1 Reply
Wire Numbers?
Is there a way to link the drawing # and wire numbers together?
ex. Drawing is 78989-031
wire #s start at 100
We would like to numbes to be 031-100, etc.
1 REPLY 1
in reply to: Warchild214
There is not a replaceable parameter for the actual drawing file name or
part of the drawing name. You could put this value into the Sheet Value
Drawing as defined on the Drawing Properties, Drawing Settings. Then you
would use the format %D-%N where the %D is the drawing sheet value.
Pat Murnen
wrote in message news:5740772@discussion.autodesk.com...
”Boost
