I have a problem with this.
If you have a common wire true your project and you choose "insert wire numbers" and there choose "drawing wide" the wire number of this common wire gets 2 numbers (see picture attached).
You can not set this wire to fixed.
You can also pick individual wires, but ......
If you have such wires in your project a drawing wide update should not affect this wire.
