Sir/Madam,
i need to change loop wire number different from main wire Number. Is there any possibilities to change.Please guide me..
Saravana
Solved by TomTom111. Go to Solution.
Hello saravanaeswaran,
The only practical way to do this where AutoCAD won't interfere with the wire numbers when they are marked fixed, is to put something like a terminal both wires connect to before they both go to your component.
This will save you from mistakes down the road when you do a retag/update on wire numbers.
The other way is to trick autoCAD.
Leave one wire connected to the component, and give it a wire number, while the other wire floats in space.
Then name the other floating wire, and then connect it to the component.
Make sure both wires are marked as fixed!
I've had to trick AutoCAD before for as-build projects, and its worked for me.
Hope this helps,
Thomas Walls
CADMASTER TECHNOLOGIES, LLC
Thank you for your reply & help,
It working.But when i try to take report(As MS Excel) any one of the wire details only comming.How to take both wire details.
Thank you for your Guidance.
In autocad electrical
when I ask the numbering of the wires (for example in sheet 5) in the format "% S-% N" the result is: ?? -5.
Pratically it doesn't see the number of the sheet.
I've the same problem with the references.
I've used a different type of title blocks (also original) with the same bad result.
Where do You think is my mistake?
Thanks for your help
Luigi
