AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wire numbering - why not as preset sequence but -, -A, -B, -C...
1 REPLY 1
denniscmt
287 Views, 1 Reply
Hi, I have implemented a PLC module and have used the parametric connectors. After setting up everything, source and destination etc through my 20 drawings of this panel I then try to label wire numbers and it didnt worked out well. All connectors start with e.g. 1 and then depending on the pins, 1A, 1B 1C and then 2 2A 2B 2C etc. How can I set it to only go on with e.g. 601, 602, 603 project wide? Thanks in advance for your kind help.
1 REPLY 1
leeholl
in reply to: denniscmt
Would changing the default wiring sequence to sequential in the project properties Wire Numbers dialog give the desired result?
Lee
”Boost
