Hi, I have implemented a PLC module and have used the parametric connectors. After setting up everything, source and destination etc through my 20 drawings of this panel I then try to label wire numbers and it didnt worked out well. All connectors start with e.g. 1 and then depending on the pins, 1A, 1B 1C and then 2 2A 2B 2C etc. How can I set it to only go on with e.g. 601, 602, 603 project wide? Thanks in advance for your kind help.
