I have a problem with wire numbering format. Usually I use a format like this: %L.%N (location.number). The problem is that I was asked for somthing like from/to wire numbering format, I'll give an example: I have a wire going from terminal 1 in the device -QF1 to terminal 5 in the device -TR. In this case wire should have a number: "-QF1:1/-TR:5". The question is - is it possible to do it using autonumbering? If so - which variables I should use and what settings (note that every wire would need to have a separate number...)? I've tried to find something in the web but didn't succeed, I did something like this in the past manually and it took me much time to do it, this time project is much bigger so it would be great if this is possible to be done automatically.
Slawek
Look in help for "Use replaceable parameters" for a list of all replaceable parameters. Not all of these are available for use in wire numbering, but you might find something useful anyway.
