Hello All,
Trying to set up ACADE for the first time, having trouble with wire numbers. Our company uses a format of labelling wires with sheet number, then line number, followed by incremented numbers, e.g. 1301, 13011, 13012, etc. on sheet 1, line 3.
I have set up the wire number format as %S%N with line reference and suffixes set up, which works fine, but the numbers appear as 113 instead of 1103 on the first 9 lines. Is there any way to add a 0 where the line is less than 10?
Such a dumb problem but I cant figure how to fix it.
You can set this up in the project properties (right click on the active project name in the project manager) under the 'wire numbers' tab.
Just click on the 'suffix setup' button , then choose the third radio button. Go up to the boxes (1st, 2nd 3rd...) and add the zero before each number.
That should sort it out.
Thanks very much for your reply.
Perhaps I didnt phase what i wanted as well as i could have. I need the line number to increment as 01, 02, 03 etc., rather than the number on the end... any help on that?
Thanks a lot for your help.
Hi mtrd_001,
It seems that if you need that zero appering in the '%N' value in the wire number, then you will need to add it in the line reference. Just edit the wire reference numbers to include the zero.
Hope that helps.
