Hello All,
Trying to set up ACADE for the first time, having trouble with wire numbers. Our company uses a format of labelling wires with sheet number, then line number, followed by incremented numbers, e.g. 1301, 13011, 13012, etc. on sheet 1, line 3.
I have set up the wire number format as %S%N with line reference and suffixes set up, which works fine, but the numbers appear as 113 instead of 1103 on the first 9 lines. Is there any way to add a 0 where the line is less than 10?
Such a dumb problem but I cant figure how to fix it.
you can setup suffix option in drawing/project properties->wire numbers as 01,02,03... Find attached image
