AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wire Numbering Basics
2 REPLIES 2
daveng
653 Views, 2 Replies
I am trying to get ACADE set-up in our company and I'm running in to problems. Our wire numbers consist of the base wire number (1AC), the sheet number (20) and the line on which it falls (4). This would give a wire number of 1AC2004. How can I automate this?
I have attached a screenshot of one of our existing drawings.
I appreciate any and all help.
2 REPLIES 2
dougmcalexander
in reply to: daveng
Set your wire number format to 1AC%S%N.  If you sheet number is 20 and the zone or rung number is 04, you will get a wire number of 1AC2004.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
daveng
in reply to: dougmcalexander
Thank you. I appreciate it.
”Boost
