AutoCAD Electrical Forum
Wire number value, based upon sheet number and terminal description.
1 REPLY 1
taclauss
326 Views, 1 Reply
Use AEPLCWIRENO on any electrical symbol.
I want to add the wire number suffix data into our electrical symbols, so the wire numbers are more descriptive and easier to generate.  A good example would be a motor encoder.   I want the wire numbers to look like this . . . . 1000A+, 1000A-, 1000B+, 1000B-, 10005+, and 100COM.  If I add the TAGA attribute to our AC drive electrical symbol, then I can use the AEPLCWIRENO command (PLC I/O) to generate the wire numbers.  %S%N.  Where can I find more information on the attributes (TAGA and etc) that can be used, when generating electrical symbols?
1 REPLY 1
dougmcalexander
in reply to: taclauss
Attributes TAGA01, TAGA02, TAGA03, etc., are used to store the address data for each addressable point on a PLC module.  If the option to use the PLC address as a wire number is checked in Drawing Properties, any wires that connect to an addressable point on a PLC will be assigned the PLC address.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
