AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wire Number Location Shifting When Proj. Wide Sig. Update
1 REPLY 1
david_brude
340 Views, 1 Reply
Was wondering if anyone else is having this problem?
When I do a project-wide signal update some of the wire number positions shift above their normal position.
If I erase the wire numbers then do a drawing wide signal update the position returns to normal. Doing a wire number move will not restore the proper spacing.
See screen captures.
David
1 REPLY 1
Wheelie22
in reply to: david_brude
I noticed before that some lisp functions use the osnap function to select something.
So when selecting a wirenumber point manualy you normaly use nearest , but if you don,t have this set but middle, it snaps to that point.
And the OSMODE is a user setting so change it once not in every drawing !
No thats not it because your number moves down not left or right.
Is the project property the same in every drawing ?
The new wire number part ?
”Boost
