AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
wire number format
6 REPLIES 6
bad
874 Views, 6 Replies
wire number format
Has anyone out there seen this before?  My wire numbers are giving the column number 1302 twice then the line number 11, I want to have the column number 1302 shown once then the line number 11 after that.  Here is an example of what I have and what I would like.
1302130211 is what I have this is what I want 130211
Under the drawing properties\wire numbers format tab I have %N and line reference checked.
Thanks in advance for any help!
bad@cad
6 REPLIES 6
cbenner
in reply to: bad
bad
in reply to: cbenner
Here us a screen shot of the drawing properties.
bad@cad
Icemanau
in reply to: bad
What is your suffix setup?
Regards Brad
Brad Coleman, Electrical Draftsman
algerj
in reply to: bad
Hi Bad,
It could be that someone (not Mentioning any names... Smiley Wink) deleted a rung (using a normal AutoCAD Delete) and placed a second one in the same location, with the same Numbering scheme.
This would give you two %N values, creating a "Duplicate" wire reference.
If you run a "DWG Aduit" (from the reports tab) on the Page it should correct itself.
You may also need to force a rung update through "Revise Ladder".
(Schematic > Edit wires/wire numbers > Add rung drop down > Revise ladder)
Let me know if you still have issue with the drawings that trying those things. (Revise ladder, and DWG Aduit).
James Alger
bad
in reply to: algerj
Success!!!  I tried the "revise ladder" option and sure enough under there it was set to 1394%N I took out the 1394 leaving the %N and now it numbers my wires like it should.
Thank you for the advise and thanks to everyone else for there input as well.  It is GREATLY appreciated!!!
bad@cad
algerj
in reply to: bad
Glad I could help.
James Alger
”Boost
