I've got the opposite problem, I'd like the WIRENO attribute to be visible by default on my terminal strips. I've looked into the Wd_wnh blocks but I cannot see where I'd set the attribute "visible".
Any suggestions?
Hi Steve
You can access the "visibility" on the properties pallet (right click and select Properties on the attribute that you want to modify).
After you make the change to the attribute, save the block.
Let me know if you need more detail,
James Alger
I checked the attributes in the block, and "WIRENO" is set visible. Yet, whenever I insert the terminal strip into a drawing the WIRENO attribute is still hidden and I need to right click->list atrributes->check visible on every terminal block.
I did redefine the block when I saved it.
Hi Steve
Can you post a picture of the Issue?
Also let us (on the forums) know what version of ACADE you are using.
There are 4 options (nothing, Wirenumber, Terminal Number [user defined], and with wire number change) for each Terminal Block Shape (circle, square, triangle, diamond, hex) in schematics.
You may have selected the wrong option for what you want.
If your talking about the panel footprint generated from the TSE, then you can select the of the options with Wire number in it (its right at the side).
Let me know,
James Alger
ACADE 2014.
I am talking about the panel footprint generated by the terminal strip editor.
On the attached picture the terminal strip on the right is what it defaults to when I insert the block.
On the left is how I want it to look, where I had to list the attributes for each terminal block and manually check visible on the WIRENO attribute.
Ideally I would like to have WIRENO default to visible just like WIRENOL and WIRENOR.
Thanks!
