AcadE wire numbers are actually block inserts with an attribute. To change
the default wire number size, just open the wire number block insert ".dwg"
file in AutoCAD and change the text size of the WIRENO attribute definition.
You will need to change several block inserts (in each of the symbol
libraries you routinely use) to cover all possibilities (there are separate
block inserts for horizontal and vertical wire numbers and for extra wire
number "copies").
The wire number block dwgs you need to adjust are these:
wd_wnh.dwg (horizontal wire number)
wd_wnv.dwg (vertical wire number)
wd_wch.dwg (horizontal "extra" wire number copy)
wd_wcv.dwg (vertical "extra" wire number copy)
... and you can find these in your AcadE symbol library (ex: c:\program
files\acade 200x\Libs\jic1, jic15, iec2, iec4,... etc.)
You won't see these new, re-sized wire numbers pop in on existing numbered
dwgs unless you erase all the wire numbers and purge the dwg of the old
block inserts.
"mbos015" wrote in message
news:29358961.1093480166790.JavaMail.jive@jiveforum2.autodesk.com...
> How do I set this? I know I can scale numbers after inserting? But how do
I set the default. looks like you can't????
