Lint
I cannot think of anything you could do to force all of the wire number
to be placed on a vertical wire. Is this a common practice that you have?
The best thing I can think of that you could do would be to just use the
MOVE WIRE NUMBER command to move those that get placed on horizontal wires
to a vertical wire. Please let me know if this is something that you would
like added as a change request. I would assume that you would like to see
an additional option allowing you to specify placing the wire numbers only
on the vertical or only on the horizontal wires where possible? Am I
correct?
Jared Bunch
Technical Support Specialist
Autodesk, Inc
"Lint" wrote in message
news:16549525.1082400455048.JavaMail.jive@jiveforum2.autodesk.com...
> Hi,
> Can I specify that a wire # goes in on a vertical wire oriented along the
wire as a default, rather than oriented horizontally? Do I just edit the
vertical block?
> Lynne
