Abhishek
In order to move the wire numbers further out from the wire, you should
be able to go into the wire number blocks and move the attribute up or out.
This will move it slightly farther from the insertion point which would give
the effect when inserting that it is farther away from the wire.
A little background info: The wire numbers are blocks, and the program
knows what wire numbers are associated with what wires because when
inserted, the insertion point of the wire number block gets placed directly
on the wire. There will be multiple blocks making up the wire numbers.
wd_wnh and wd_wnv Keep this in mind and be careful when editing this block.
If you use the Extra wire numbers, these are also block and you will need to
modify them as well. wd_wch and wd_wcv
Please keep in mind that this problem is occurring because you are
scaling as things are inserted, should you ever set the scale back to 1,
these blocks being modified will probably need changed back to their
original forms in order to look correct again. You may want to create
copies before you modify them!
Jared Bunch
Technical Support Specialist
Autodesk, Inc
"Abhishek Singhal"
wrote in message
news:3ffd6ae3_1@statler...
> Hello All
> When I do automatic wire numbering, the wire numbers are placed above the
> wire. On scaling them (by say a factor of 2), I find they are placed too
> close to the wire.
> I can use the Move Attrib command but that seems too tedious.
> Is there an easier / better way out
> Thanks and Regards
> Abhishek Singhal
