Are you using the copy circuit tool to copy the wire to another drawing? If so, are your wire numbers fixed? You can use Wire Number Edit to make a wire fixed. If you don't uncheck the Make Fixed box when you "OK" from the editor the wire will become fixed anyway. Fixed wire numbers normally display in a different color, set by the layer WIREFIXED. You can choose any color you wish, perhaps green for fixed and yellow for layer WIRENO (UNFIXED wires). Then they are easy to see on the screen. Just bear in mind that each drawing has its own configuration and it may not necessarily match with the drawing you copied from, unless you are using a common template. Be sure that the valid wire layer exists in the drawing copied to and that the wire layer is named in the Drawing Configuration, remembering that wild cards are acceptable, such as RED*, BLK*, etc.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
