AutoCAD Electrical General Discussion
New Member
emailbilly
Message 1 of 2 (132 Views)
Wire List
132 Views, 1 Replies
01-10-2013 10:00 AM
I had some schematic made using AUTOCAD, my goal is to export the wire list including the information of the wire name, from/to, wire guage and the length. I believe AUTOCAD Electrical should be the right software for this kind of reporting. Could anyone give me some guideline? Thanks
Valued Contributor
lionSG
Message 2 of 2 (120 Views)
Re: Wire List
01-10-2013 05:45 PM in reply to: emailbilly
I believe you need to convert your blocks into electrical components and lines into wires first.
you can make use of the Conversion Tools tab to do that.
Then you can do a to/From report from the Report tab.
If you need more info, you can look into the Tutorial in the help files.
Hope this helps.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
