Can anyone explain us, How to extract the wire number, Wire Type, Gauge & Wire length from Autocad Electrical drawing to MS Excel or Spread sheet.
Please guide to do this.
Thanks & Regard,
Saravanaeswaran.M
Solved by vladop. Go to Solution.
For wire number, wire type... use Reports.
There are no tools for wire routing and wire length in ACE, but you can check AE eXtender Wire Routing fom ACERI.
Vlado
Thanks for your reply & help.
How to extract From(One component)/To(Other component) details of the wires connected in components of a drawing and also wire number of the same.
I don't use "wire reaports" but I think that you should use ACE_REPORT_SCHEM command and then select "From/To" or "Wire Label" report
AEAIPEXPORT I think is the command to create an XML file to import into Inventor.
