AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wire layer change
2 REPLIES 2
375 Views, 2 Replies
Wire layer change
Dear Sir/Madam,
I'm using Electrical Autocad2011.I need take Report(From/To) for wiring. I'm using Symbols or Create own Symbols By Symbol Builder. When i connect three Different types of wire on single wire connection terminal.When i change any one wire type or layer by using AECONVERTWIRETYPE Command all remaining  wire types are also changed. How can i use three different types (Ex.Finolex,Teflon, Nyvin Etc.) of wires on the same Terminal. Please Help me.
Thanks for your Helps & Guidance,
Saravana
2 REPLIES 2
Un-check the box, then you can change individual segments of the wire
Dear Sir,
Sorry sir i think that is a silly question. Thank yor for your help.
Thank you,
Saravana
”Boost
