Dear Sir/Madam,
I'm using Electrical Autocad2011.I need take Report(From/To) for wiring. I'm using Symbols or Create own Symbols By Symbol Builder. When i connect three Different types of wire on single wire connection terminal.When i change any one wire type or layer by using AECONVERTWIRETYPE Command all remaining wire types are also changed. How can i use three different types (Ex.Finolex,Teflon, Nyvin Etc.) of wires on the same Terminal. Please Help me.
Thanks for your Helps & Guidance,
Saravana
