Hi Doug,
I'm finding that with the client requesting a B1 border, the wire gap is almost unnoticable. I don't want to mess with the feature scale factor, but is there really no way to force AE to insert a larger gap?
Cheers,
Mike
Assuming you mean the gap when using inline wire numbers, look in the project properties under the Wire Numbers tab.
In the 'New Wire Number Placement' section, there should be a button labeled 'Gap Setup'.
Adjust the two boxes labelled 'A' and set box 'C' to zero.
This will adjust the gap for Inline wire numbers.
For wire numbers above and below the wire, I believe it is as previously posted.
Regards Brad
Brad Coleman, Electrical Draftsman
