Hi
Is there a way to change Wire Gap Size or is it fixed?
/Johnny
Hi!
Yes you can.
Select Project or drawing propeties --> Wire numbers --> On the connection line (smth like that, I have russian ACE). See pic. plz for more details.
Sorry I've just thought that you haven't meant the wire number gap. Translation peculiarities. In that case, I know only the manual way to change the gap radius - from the context menu. But then you have to use the AutoCAD command Cut .
Probably this method will not suit you.
