Is there a way to exclude wires on certain layers from showing up in reports?
Solved by ccad2509. Go to Solution.
if you go to from to report
when you get to the report generator stage select user post
there is an option to select certain layers to report
you filter the ones you want
otherwise you can select edit mode at the report generator stage
and you edit delete individual wires as required before you generate a report
