AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wire from/to report errors
1 REPLY 1
141 Views, 1 Reply
When i run a wire from/to report i am getting incorrect wire numbers associated with the wire being reported.
Example:
the wire from Device K1, term 7 to Device J1, term A reports as an WHT/BLU 18 AWG wire on line number 233. this seams ok until i check my report against my drawing. in-fact everything the report tells me is correct except the wire number it should be a 209E ( long way from 233 ). now i have rebuilt the database, removed and renumbered all wires, purged, audited, reloaded the project, even had other users run the report and the error persist, the wire isn't connected to line 233 by any means. i am at my wits end here. any help is greatly appreciated.
1 REPLY 1
Hi, not sure how you've got into this mess (or how you get out of it), but I think somehow the wire numbers in your report are being manipulated into a hex format, ie wire 233 returns a hex value of E9.
Hope this sets you on the right course.
”Boost
