Please post an example of what you are trying to do. I'm not sure I understand. I have components with over 100 pins and they all show up on the wire list. Did you make the symbol yourself? If so, make sure each terminal/pin has a unique identifier. There should be a TERM01 and a matching X?TERM01, and TERM02 and matching X?TERM02, etc. The "?" should be either 1 (wire from right), 2 (wire from top), 4 (wire from left), or 8 (wire from bottom).
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
