AutoCAD Electrical Forum
wire cross
3 REPLIES 3
453 Views, 3 Replies
wire cross
When I select solid for wire crossing in the dwg configuration and close dialog box, then insert a wire crossing another wire I am still getting the loop. When I check the drawing configuration, it has reverted back to the loop setting for wire crossing. Is this a bug or am I missing something?
thanks for any response.
3 REPLIES 3
Are you dismissing the dialog by hitting the "X" in the upper right hand corner of the dialog or by hitting "OK" button? If you're hitting the "X" to dismiss the dialog, I believe this is being treated the same as if you'd hit "Cancel" and the configuration change is not saved. Let me know... thanks! Nate. "lauraw" wrote in message news:17559549.1087841586951.JavaMail.jive@jiveforum2.autodesk.com... > When I select solid for wire crossing in the dwg configuration and close dialog box, then insert a wire crossing another wire I am still getting the loop. When I check the drawing configuration, it has reverted back to the loop setting for wire crossing. Is this a bug or am I missing something? > > thanks for any response.
thank you nate... guess I was having a brain... you know what...
Could have sworn I selected ok in past attempts!!!
working properly now!!!!
pichurin
Does anybody know how I can configure AutoCad Electrical to have wire loops with the size I set?
”Boost
