Hi there,
I´m experimenting using ACADE using single line drawings such that components shown on the single line drawings are also represented on a building layout diagram. I´m using the wdtagalt attribute to show the same component on seperate drawings and when inserting the appropriate symbol on the layout drawing I set the scale scematic setting to 30 in the insert component dialog box. The problem occurs when I need to draw a wire from the symbol as the wire connections don´t seem to scale up with the symbol thereby making it difficult to see them!
One other thing I´m experiencing is that if the UCS is such that "North" is pointing at 3 oclock the insert wire tool seems to have problems?
Any suggestions appreciated.
Regards, Gary
Solved by CAD-ICE. Go to Solution.
Hello Dough,
well that´s basically what I meant that is, when pressing "X" to see the wire connections, the green wire connections aren´t scaled up. So when using symbols on a bigger scale drawing for instance on a building layout, the green wire connections are barely visible.
Thank´s again,
Regards, Gary
Ok I get it...was kind of hoping that the green temporary graphics had something to do with the term attributes.
Anyway it would be nice if this function did scale up automatically with the term attributes...don´t you agree?
I hope Autodesk will register this on the wish list for later issues.
By the way, I posted another post yesterday regarding using ACADE for representation of component on a building layout. Do you have any comments?
Thank´s again Dough for all your support through the years
Regards, Gary
Hi Dough and thank´s for thorogh answers as usual.
I can as you mention alway´s add a graphical connection point and that´s what I´m going to do.
Best regards, Gary
