My colleague and I have introduced AutoCAD Electrical to our company, convincing them that A Electrical's efficiency and speed that it can produce is much better than ordinary AutoCAD Vanilla, when it comes to using more then 2000 wire connections.
Although we are trying our best to convince our management, we are facing some difficulties in trying to achieve some commands in showing the 'Wire Coulur/ID' on the other side of a cable (please see attached).
Basically, when assigning the Cable Marker, we usually mark the cable by a color, say Bl, Bk, R... Then on the other side of the cable, obviously you use the 'Copy Wire Numbers' command, but this works only when you've numbered the wires by the 'Automatic Wire Numbers'.
What we need is that instead of showing the wire numbers on the other side, we would like to show the actual 'Cable Marker' or the color, without going to manually change the wire numbers into the desired colors.
Can anyone help??
Regards
Vigan
