Turn your properties toolbar on if it is turned off. You will probably find that the colour is set to colour9 rather than 'By Layer'.
Change this back to by layer and you should be right. Select all the affected lines and change those to by layer as well and that will fix everything.
Regards Brad
Brad Coleman, Electrical Draftsman
