The wire color/gauge labels are generated using regular ACAD dimension text.
That is why you can manipulate them with regular ACAD commands like move and
rotate, versus the Edit Attribute commands.
wrote in message news:5991055@discussion.autodesk.com...
Thank you for the reply Scott, but the Wire Color/Gauge Leader is not a
block. It is just text generated from the WDW mapping file.
I was thinking about editing the Lisp.
Does anyone know if this is possible?
Thanks again,
Jeff
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
