Well, it looks like I was partly wrong on this. The Rename Schematic Layers
command in AcadE does not update the wire color/gauge labels. There still
may be other reasons to use it rather than the AutoCAD layer manager to
rename layers though.
On the ribbon for renaming schematic layers -
Schematic tab Other Tools panel Drawing Properties drop-down Rename
Layers.
The Change/Convert Wire Type commnad does update the wire color/gauge
labels.
If you want to change wires from one layer to another I would use the
Change/Convert Wire Type.
Schematic tab Edit Wires/Wire Numbers panel Modify Wire Type drop-down
Pat Murnen
wrote in message
news:6343532@discussion.autodesk.com...
Hi Pat
I'm using AcadeE 2010sp1
What AcadE commands for layer control are you referring to, I usually use
layer properties to control layers.
