@jean.renaud.grimard wrote:
You are just saying what I already know. I will try to be more clear about my first question. Follow these steps :
1 - See attached image (printscreen from ACADE help)
2 - Look the section where WIRENOxx attribute is defined
3 - See that we can also use WIRENOxxA and WIRENOxxB, and so on.
This option seems to be for "normal" footprints, not for terminal strips. I would like to know if anything similar applies to terminal strips, and which are the corresponding attributes to be used.
There is no more info about this functionality in the help. There is no example of these attributes (with A,B,C...) in any block found in ACADE directory. Is there any expert/core programmer there to check in the source code ? I think they are only people who can seek for an answer.
Thanks !
Did you ever find a solutiuon to this? I need the same thing.
