Hello there
I have created a panel footprint here inserted (FP_005 - Test switch assembly). This footprint has wire connection attributes (TERMxx and WIRENOxx), which according to AcadE 2010 manual, if linked to schematic components through its TAG1/P_TAG1 attribute, can display the information of the wire connected to the related schematic component, by running the "Wire Annotation" tool.
What I am trying to do is, link the test switches components ( HDV1_003 -- in 3 line schematic drawing) to the test switch assembly ( in wiring drawing), and have a wire annotation list -- of wires connected to each one of the test switches -- displayed under the test switch assembly symbol. I am having problems with this last step.
When I run a wire annotation of the panel footprint, AcadE outputs a msg : "No schematic wire connections found for … " , Even though the 2 symbols (test switch and test switch assembly) are correctly linked, both TERMxx attributes are given the same value(1 and 2) , and the schematic symbol IS connected to labeled wires.
Do you have any suggestion for this problem?
Beforehand, thanks a lot !
