I've found a "non-constant" problem in this situation :
1 - Create only one drawing into a blank project.
2 - Place 2 schematic components ("A" and "B") into this drawing.
3 - Place the panel footprint (with wiring annotation attributes) corresponding to "A" on the same drawing.
4 - Trace wires between schematic components "A" and "B".
5 - Update wiring annotation on the Panel footprint "A"
The Panel footprint Wiring Annotation will not be correctly updated.
But the following works :
1 - Create two drawings; schematic drawing and wiring drawing
2 - Place Schematic conmponents "A" and "B" on schematic drawing
3 - Insert panel footprint corresponding to "A" into wiring drawing
4 - Come back to Schematic drawing. Trace some wire between "A" and "B".
5 - Go to wiring drawing then update wiring annotation.
Wiring annotation will be correctly updated.
If i trigger a full database rebuild in the case of only one drawing, then wiring annotation will be okay after the rebuild. But this is very time-wasting...
It seems that ACADE database will not take account of changes on a drawing if we do not go to another drawing...
BUT, I've closed then restarted ACADE completely, and the problem do not reproduce.
Anybody heard about anything like that ? could this be explained by any hidden variable or memory problem ?
