Hello everyone
I have a problem with Autocad Electrical 2015
For example, if I try to open a file , it does not open the window classic , but brings me back to the command line .
Same if I try to save or save as
Possible that Autodesk has made the same mistakes with Windows updates ?
Please can you give me a solution ?
Solved by chiab_gigi. Go to Solution.
Solved by rhesusminus. Go to Solution.
Is everything else working ok?
Try to type FILEDIA at the command line, and press enter. Then set this property to 1. Try to open again....
thanks works fine now
sorry I can take advantage to make a other question
I looked around on the internet but I found little arguments about the connection between AutoCAD and Excel
in particular it is possible to excel manipulate attributes of a block ?
Yes, no problem.
Use these two buttons:
1. Export project data to excel (or some other format)
2. Import project data from excel (or some other format)
While in excel, columns with a header within parenthesis's, like (HDL), are not editable.
