AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
When I try to access Panel -> Editor : Error log file
1 REPLY 1
363 Views, 1 Reply
I have trouble accessing theterminal block 'Editor' tab. Error saying 'Error log file', Reason:'String does not translate to a positive number'. I am not sure how to debug this problem.
1 REPLY 1
s.wile
Well I think you may have found a bug! If you didn't you helped me find one while poking around on this question.
I was putting together a list of questions for you to answer that may prompt more response from the group. In the process I think I found your problem.
I can change a terminal's number to a negative "-9" and the footprints and all update. However when I try to edit the terminal strip after this, my Electrical crashes pretty hard with an "Exception in VEVAL-STR+ ARX Cammand" error. This is followed by a number of Unhandled Exceptions. After that a lot of my Electrical commands will not work. I tried this on several terminal strips in this project and had the same results every time.
Check your terminal strip for negative numbers and get rid of them. I bet your problem goes away.
Stan Wile
http://myacade.blogspot.com/
IMAGINiT Technologies
”Boost
