AutoCAD Electrical Forum
what a project means to me.
0 REPLIES 0
Message 1 of 1
TRENTBERGEN
263 Views, 0 Replies
So when we do a project it looks something like the below. Each project is actually a seperate PO. And yes i do need to track this. Now it looks like this because we usually do plant wide controls. And we have to keep track of multiple PO'd projects and change orders. We meed to track not only the plant but when things were added. What project they were added in and then total the bom's for those specific projects up for billing and accounting purposes.  Sheets within a folder should auto number. restarting at sheet 1. but with the same drawing number.  I should be able to assign a project number to every part so i can total up the cost for each individual po. I may be tracking years worth of data and i need to do this fast.  I need to print out reports for accounting or send this directly to our ERP software.   i may have 300 enclosures in a plant and i need to track this from one location.  i need refrencing to update automatically. currently were doing this fairly manually. however, in the future i hope to have most of this automated.  Can it be done? and how easily can it be done. Also is there any way to have fuses and circuit breakers add up all the fla's of all the devices connected to them and possibly set up a warning for the designer that they have crossed the maximum load of their protective device. is any of this possible or is it a pipe dream.
1. overview- drawing 32-1-5698  starting on project 12156
      a. sheet 1. cover sheet
      b. sheet 2.  drawing refrences
      c. sheet 3. network topology
      d. sheet 4.  enclosure list
      e. sheet 5.  enclosure pull wire
2. Enclosure 1 drawing 22-1-0568  - added during project 14213
      a. sheet 1. cover sheet - drawing refrences
      b. sheet 2.  internal network topology
      c. sheet 3. 120v power distribution
      d. sheet 4.  24v power distribution
      e. sheet 5-12. remote io
              i. pressure switch added during project 14213-2
              ii. level transmitter added during project 16532
      f. sheet 13. spare sheet
      g. sheet 14-15.enclosure layout
      h. sheet 16. bom
3. Enclosure 2 drawing 22-1-0568 - added during project 16532  - different project same drawing reference.
4. enlosure 3 drawing 52-1-0698 - added during project 15633
I've attached a partial example sample.  things have changed quite a bit.  but this will give you a general idea. it also encompassed things added 15 years ago. so it can get confusing but this is generally this issue im having i want a auto cad elec project to actual represent an entire plant.  And use the folder structure to organize an enclosure drawing package.  I may refence the same drawing in multiple projects because they bought the exact same equipment modual 2 years later than the other. and i don't want to redraw this so i reference the same drawing. but i still need to capture this.  I need a way of pulling this all together.
attached files are the property of cyclonaire corp.
0 REPLIES 0
”Boost
